oil pressure drop
oil pressure drop
hello, i have a new 347 stroker with less than 100 miles on it, in a 93 hatch. i am having problems with my oil pressure dropping when i come to a stop after the engine was under a load. i will be driving, and will let the car out of gear, to come to a stop sign, and the idle and oil pressure will just plummit. i understand when the idle of the car gets low the oil pressure drops also, but when i say drops, the oil pressure gage bottoms out. when i let it sit at an idle, without the motor ever having a load on it, the oil pressure is fine.. i dont have any idea why my oil pressure is inconsitant. does anyone have any ideas?
RE: oil pressure drop
How is the oil level and how many quarts are in there?
What oil pan do you have? factory 5 quarts or canton 6/7 quarts?
Who did the 347 build? Was the Crank New OR TURNED?
Ive seen STD Bearings used on .010 turned cranks. and just because a bearing says .010 dont meen it is.
Sounds like maybe the pickup is too high, hits the brakes and the oil sloshes away from the pickup. Stock pan, or is it a baffled pan? And does it do it when you corner hard also? Definately check it with a good gauge though, stock gauges are notoriously innaccurate,
ORIGINAL: 67mustang302
Matt's 95 Stang
10-05-2015 07:16 AM
