I need fuel advice now!!!!!
Old 04-19-2008, 09:49 PM
5.0 85 GT
5.0 85 GT's Avatar
Default I need fuel advice now!!!!!
OK, so i have my good old 94 gt which i love..but heres somehtign i do not love...my gas mileage
I no everyone complains about it but u complainers are getting 250-300 to the tank, i am getting 120 to the tank.!
Does a Cold air intake, a little elss than mild cam, catted x and catback and a chip really take away my MPG's??? It costs almost $50 bucks to fill the tank with REGULAR whcih is 87 Octane and i get 20-25 miles ot a quarter tank...
Are there any valves sensors somehitgn i can clean or fix to up my mileage???? it has a fairly new distributor and mallory plugs n wires..shjould i see fi they are gapped correctly?? my tires are up to pressure as well so idk what is killing me, i launch very easily, take off from second gear soemtimes, use neutral down hills and adjusted my idle very low so when i go into neutral is like its not even running....tell me somethign.!!!!!!!!!!!!!!!!!!!!!!!!!!!!! please!!!!!
5.0 85 GT is offline
Old 04-20-2008, 12:00 AM
nitrous_bob
nitrous_bob's Avatar
Default RE: I need fuel advice now!!!!!
starting in 2nd is not fuel efficient, what gears do you have ? is the speedo corrected ?
how are you figuring out your mpg ??? the only proper way to do it is to topoff w/ gas, reset your odo, and then drive for about 100 miles or the whole tank either way. then topoff again and use those miles, against those gallons.
i have 4.10's and get 21 mpg on my tired 146k motor
nitrous_bob is offline
Old 04-20-2008, 01:04 AM
Boosted5.slow
Boosted5.slow's Avatar
Fresh tune up,backing off timing, Theres quite abit you can do.
heres a website on mpg hopefully it helps
http://www.fordf150.net/howto/fueleconomy.php
http://www.fueleconomy.gov/FEG/drive.shtml
Boosted5.slow is offline
Old 04-20-2008, 11:36 AM
5.0 85 GT
5.0 85 GT's Avatar
ok thansk for the help, and i have 3:08 rear gear everythign is correct the speedo etc...and i fill up a lil past full reset my odometer, drive till half a tank, ill get maybe 80 miles if that to half a tank, then assume i get another 80 to the second half, so 160 ish to a tank, or ill fill up again and use the miles against the gallons, it is horrible on gas..she is good not he highway but around town i jsut die, and i guess i wont be using second gear out the hoel then..
Old 04-20-2008, 11:51 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
try cleaning the maf if you have a k&n type oil filter....oil residue can contaminte maf a skew readings and in turn affect fuel mpg's
mjr46 is offline
Old 04-20-2008, 01:32 PM
nitrous_bob
ORIGINAL: 5.0 85 GT
she is good on the highway but around town i jsut die
well if your talking city driving....yeah hard to get 12 mpg really, as long as your getting 22-24 on the all hiway miles...you got what you got
Old 04-20-2008, 02:27 PM
fordboyyfm
fordboyyfm's Avatar
im sure te chip isnt helping, they always claim better fuel milage but i never beleive it.
fordboyyfm is offline
Old 04-20-2008, 04:29 PM
302army187
302army187's Avatar
make sure your o2's are good also, i would check/clean/replace all sensors.....
302army187 is offline
Old 04-21-2008, 08:56 PM
5.0 85 GT
5.0 85 GT's Avatar
yea thanks i just did my x pipe and got 2 new 02 sensors..so i am good there, ill try cleanin the maf
Jb145700
08-21-2022 06:37 AM
svfetter
10-05-2015 11:39 AM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: I need fuel advice now!!!!!
