0-60mph
Old 04-22-2008, 12:40 PM
94StinkinLincoln
94StinkinLincoln's Avatar
Default 0-60mph
sn95
331
eddy rpm 2.02 heads
xe270hr-14 cam
rpm 2 intake
10.3:1 compression
aode
3.27's
26.1in mickeys
converter flashing around 2500
leaving off idle
afr was about 12.0, so it was a little rich.
4 degrees added globally to timing
im getting a 0-60 of 6 seconds (this is using BE and EA to datalog my run, its not a g-tech or anything lol this is accurate.)
too me that sounds a little slow...
94StinkinLincoln is offline
Old 04-22-2008, 01:11 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: 0-60mph
That is a little slow if the info is accurate. But it may be the gears and auto. There is a calculator to measure 0-60 using short time and 1/8 speed and time. According to that my 0-60 is 3.1 seconds .
WhiteWindsor is offline
Old 04-22-2008, 01:17 PM
94StinkinLincoln
Default RE: 0-60mph
i was thinkin that was a little slow, stock is 6.6-6.7
maby that converter, that was custom made, the first one wasnt the best looking and after 400 miles it burnt up, it was a 3500, this one should have been the same but its not...maby is some of the problem.
Old 04-22-2008, 03:38 PM
ckyguy68
ckyguy68's Avatar
Default RE: 0-60mph
Dude thats slow as f@ck. With a built motor and stall converter you should be pulling off sub-5 times no problemo
ckyguy68 is offline
Old 04-23-2008, 07:41 PM
94StinkinLincoln
Default RE: 0-60mph
bump
StriderTacticaL
10-29-2009 12:59 AM
Powdered Toast Man
01-01-2009 11:54 AM
imyy4u
10-26-2007 04:27 PM
chrisc
09-01-2007 04:17 PM
legendlime
11-03-2006 03:24 PM
Quick Reply: 0-60mph
