Smog Pump Delete
Smog Pump Delete
Can anyone tell me specific directions for removal...as in which hoses to remove/plug. I have cats on my H currently, but will be going O/R here soon + will make header install easier.
RE: Smog Pump Delete
Ive tried the searches and 80% is useless. 1/2 of the threads contains 1 reply,"Do a search". We need to sticky alot ofthis ****z so everyone doesn't have to explain this over and over.
Need sticky's for: GT40/P stuffoff Explorer/Mountaineer/Cobra
Basic Tune Up
Cheap mods
Air(smog) Delete
Basic Tune Up
Cheap mods
Air(smog) Delete
As long as you have factory cats on the car you will need the smog pump. Since you plan on changing the exhaust anyway, take the hoses off the smog pump, unbolt the smog pump from thebraket, pullthe hose off the tube that goes to the back of the heads ( you can either block it off or unbolt it andreinstall blots in the holes in the back of the heads), and lastly jack the car up and remove the tube that travels from theh-pipeto the engine compartment. You will need to plug the tube on theh-pipeor you will have an exhaust leak (put asmall length of hose onitwith a bolt in it orpinch it together and weld itshut). You will also need a shorter belt (run from crank pulley directly to the alternator).
Hopethis helps.
Hopethis helps.
ORIGINAL: camaroeater
Thanks...I found some Ford boltsdesigned forplugging heads, its part # F4ZZ6E086A. I wondering if the charcoal canisters stay or go.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
