TPS adjustment question
i have everything set up, i ahve pins in the TPS wires ect. the multi meter
and w/e
with ignition on car off multi meter is showing -4.18
with car on at idle it shows the same thing...
i thought it was supposed to be between .85 and 1
and w/e
RE: TPS adjustment question
(+) DVOM lead on green wire
(COM) DVOM lead on black wire
If reading is negative you have other problems...... BTW, did you run the DIY KOEO/KOER/Cylinder Balance Self-Tests .... suggest you do..... what problem are you trying to fix?.....LUK
yeah i bet your on the wrong wires..... how did you pierce them ? safety pins ?
and you WILL get a diff reading if you go black to ground... instead of the black wire. you need to be in the black tps wire w/ the black lead
im having what seems to be a fuel delivery issue
where under part throttle and somtimes WOT throttle the motor is not getting enough fuel
ifi go to give it any gas at all the car wll just fall on its face, and start popping through the intake.
thought maybe the TPS is not giving the computer accurate readings so when i do give it throttle computer barely giving it enough fuel cuz the tps stopped telling it how much throttle im giving it.
okay i figured it out i had the wiring wrong like nitrous bob said... idk how i had the color wires written infront of me... but i some how pierced the orange and green instead of the black and green
but any way at idle (im using a sewing pin through the wire) im pull .74 my idle is pretty good though at 800rpms... it moves around but hte typical idle is 800rpms... if i raise the idle voltage will that not raise my idle as well
and could it solve my surging/popping issue im having at part throttle
ORIGINAL: Alero99
You may want to bump the idle speed up though... 850 maybe???
ORIGINAL: dudeboy
Changing the tps setting can't/won't affect the idle...neither quality nor rpm...
ORIGINAL: Alero99
69MustangCoupe393cid
10-03-2015 10:33 AM
09-16-2015 07:53 PM
Daddys Girls GTs
09-14-2015 08:46 PM
