timing on 94 gt
timing on 94 gt
Ihave a 94 gt with just Flowmasters, Ford 9mm Plug wires, MSD Coil, plugs are gaped at .52 and Cold Air Induction,I was wanting to know whatshould Iset the timing at? Right now i have it a 15*, but when you get on it (wide open throtle), itwants to spike.So what should i set it at? Thanks.
RE: timing on 94 gt
I have tryed seting it at 15*/13*/6*/ and 0*,and it still spikes at full throtle.
My plug gap is .52,could the plugs be the problem. Plus before I started to Mess with the timing,it would backfire out of the intake? Anyanswers to any of this?
RE: timing on 94 gt
spike you meen pinging?mine would only allow 8* until i changed the 4 cats backpressure on the exhuast valve? sounds like you have another problem besides timing if its spitting out the intake or the diz. isnt on top dead center
RE: timing on 94 gt
well i'm sure the gap is actually .052" cuz no way could you get more than a 1/2 inch on it
but try going down to about .045" and see what happens ? what plugs ? DO NOT USE platinum
and +1 whaddya mean "spikes" ???? fuel pressure ? it will always spike under wot if yes
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
