stock(A9L) vs. Cobra (x3z) computer
Old 04-25-2008, 11:17 AM
95_gtskunk
95_gtskunk's Avatar
Default RE: stock(A9L) vs. Cobra (x3z) computer
Odd question.. What year range did they use the A9L ECM? and would the 95 GT stock computer be ok?
95_gtskunk is offline
Old 04-25-2008, 01:27 PM
dudeboy
dudeboy's Avatar
ORIGINAL: 95_gtskunk
The A9L and 95 GT use ecu's from different Strategies, and are not interchangeable.
Not sure what year they started using the A9L, but it ended in 1993...
dudeboy is offline
Old 04-25-2008, 01:47 PM
95_gtskunk
95_gtskunk's Avatar
ORIGINAL: dudeboy
So based on that.. What I need to know i guess is my car ran for 19# injectors similar to that of cobras? Or is it ran from my maf readings allowing me to upgrade my injector size without any problems?
Old 04-25-2008, 01:51 PM
dudeboy
dudeboy's Avatar
ORIGINAL: dudeboy
So, you have a 95GT, and want to use a larger injector?
To do this you will need an aftermarket MAF meter, which will be 'calibrated' for your Injectors and ecu.
(this is assuming a custom tune is not in your future)
dudeboy is offline
Old 04-25-2008, 01:58 PM
95_gtskunk
95_gtskunk's Avatar
Exactly that makes good sense. No a custom tune is not in my future.. (kinda pricey?) But say I want 24# injectors. What size of MAF would be appropriate? This also sparks my other question I asked in the Discussion forum.. I wanna cam my new motor.. Whats a good cam to use with stock heads? I want a rough idle.. Would my ECM allow for a larger cam?
Old 04-26-2008, 12:01 AM
dudeboy
dudeboy's Avatar
I would go 75mm or 80mm, but others who have posted in this thread may call that 'Way too big' [&:]
Your ecu will be less accepting than the A9* series computers. I don't have ANY experience with the sn95 ecu, so I really don't want to offer any help that may turn out to be wrong...
If you want to run 24's in a sn95 (94-95) Mustang GT, then you have 2 options...
1. Install the 24's, and Install a Cobra ecu.
2. Install the 24's, and Install an aftermarket MAF meter for the 24's and factor ecu.
hope that makes sense,
jason
dudeboy is offline
11-10-2015 11:39 AM
1TUFF302
11-05-2015 04:02 PM
JT76
09-20-2015 11:32 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: stock(A9L) vs. Cobra (x3z) computer
