Airbag light stays on?
Old 04-26-2008, 08:35 AM
mrchaikel
mrchaikel's Avatar
Default Airbag light stays on?
I have a 92 LX and just had a CD player installed. I notice that the airbag light stays on after putting the key in the ignition. Sometimes the light does not come on. Seems to be intermittent. It does not flash or beep but rather it is steady on. The car had a stock radio and EQ and the installer found the harness close to the glove box. Any help on fixing this would be appreciated.
mrchaikel is offline
Old 04-26-2008, 09:51 AM
mrchaikel
mrchaikel's Avatar
Default RE: Airbag light stays on?
Problem fixed. I decided to remove the radio, radio faceplate and faceplate around AC controls. I noticed a blue module in the back with 2 plugs (female ends) empty. In front of me sat 2 plugs (male end.) I plugged them in and now when I put the key in the ignition, the lights comes on for 6 seconds and then goes off. Sloppy radio installer. If you want a job done right, do it yourself! I am glad I did not have to bring it into the stealer.
Old 04-26-2008, 11:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^^^^^^^^that would be the air bag module
mjr46 is offline
Seanam
10-04-2015 10:15 AM
accarter
09-21-2015 11:56 PM
Colin Ringle
09-15-2015 09:27 PM
rksnow1
09-14-2015 08:46 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Airbag light stays on?
