What do you make of this.
Old 04-26-2008, 06:16 PM
brentloftis
brentloftis's Avatar
Default RE: What do you make of this.
Have you checked the timing?Sounds like it is advanced to far and cutting out. Check the codes and timing if you can.
brentloftis is offline
Old 04-26-2008, 07:18 PM
gobabygo
gobabygo's Avatar
Yeah the guy I bought the project from said someone he knew advanced it. But I got my OBD1 reader and i got a few codes that point to the MAF. 157 and 159 low voltage and 159 is a fault in the MAF sensor. Would the MAF cause the car to cut out?
gobabygo is offline
Old 04-26-2008, 07:30 PM
gobabygo
gobabygo's Avatar
According to the book for the tester the cylinder balance test gives codes like 10-20-30 etc. to show what cyl is not contributing to the car's performance. I got a code that said 8 but had the "cyl" above it. Not sure of that means there's a problem with that or not.
gobabygo is offline
Old 04-27-2008, 11:54 AM
gobabygo
gobabygo's Avatar
Would the MAF cause the car to cut out like that?
gobabygo is offline
mtgldr
02-03-2024 09:00 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: What do you make of this.
