347 scat rotating assembly
Old 04-26-2008, 08:11 PM
HACKGT350
HACKGT350's Avatar
Default 347 scat rotating assembly
alright i have been doing a little bit of looking around and i like the way this assembly looks. im just looking for a little feed back from anyone that has used this assembly or know of anyone that has used it before. i did try searching on the forum but didnt really come up with anything i liked or that was helpful. if anyone knows of something better let me know http://www.mustangsunlimited.com/ite...asp?T1=PC97+01
HACKGT350 is offline
Old 04-26-2008, 09:03 PM
fordboyyfm
fordboyyfm's Avatar
Default RE: 347 scat rotating assembly
if you look around you should be able to get everything a little cheaper, that doesnt even come with bearings.
fordboyyfm is offline
Old 04-26-2008, 09:09 PM
HACKGT350
HACKGT350's Avatar
yeah i saw that. would you be able to point me towards a good website for stroker kits?
Old 04-26-2008, 09:24 PM
fordboyyfm
fordboyyfm's Avatar
its been a while since i did mine so i dont really remember. look on ebay. and unless your going for serious power just get I beams instead of the H beams, save you some money there.
Old 04-26-2008, 09:31 PM
HACKGT350
HACKGT350's Avatar
im looking for 400+ n/a and then a 100-150 shot on top of that
Old 04-26-2008, 09:43 PM
67mustang302
67mustang302's Avatar
4340 I beam rods will take at least as much power as the stock block will. There's no need to spend money on h beams unless you have an aftermarket block and plan on using it.
67mustang302 is offline
Old 04-26-2008, 09:50 PM
HACKGT350
HACKGT350's Avatar
i was planning on getting the boss block or a dart block so yes i do plan on using it
Old 04-26-2008, 10:04 PM
67mustang302
400 + a 100-150 shot should be fine on a stock block. If you spend the money on a Dart block etc, then you might as well build for more n/a power and run a bigger shot.
Old 04-26-2008, 10:09 PM
w8less
w8less's Avatar
PM me hack
w8less is offline
Old 04-26-2008, 10:37 PM
PJC Racing
PJC Racing's Avatar
fordstrokers.com, Jim can help you with whatever you need.
400 with 100-150 shot, can live in a stock block (if you keep the rpm's managable), but going with an after market block will give piece of mind and room to grow.
PJC Racing is offline
Quick Reply: 347 scat rotating assembly
