valve cover clearance?
so i am putting on gt 40 heads with cobra rockers (1.7 i believe) and was wondering if i can keep my stock valve covers on...i really want to jus keep the stock ones on so give me any kind of advice. thanks
RE: valve cover clearance?
I just did a a head/intake swap using Gt40 tubular and Gt40 Y heads. I did not have to clearance the oil baffle what so ever. I used the stock Ford Motorsport valve cover gaskets (rubber with steel core) and no clearance issues.
Just to be safe though, I got some play dough, and put it between the number 1 rockers and the oil baffle, I then bolted down the valve cover without any gasket. I then turned the motor by hand several times, and then checked the play dough. There was a very small impression in the play dough, but nothing too drastic.
I would suggest that you try the same.
Because the Cobra RRs don't have an adjustable nut on the top, they don't seem to have clearance issues.
Hopefully this helps you out.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
