Please Help...car keeps dying
Old 04-29-2008, 09:36 PM
Texas5.0
Texas5.0's Avatar
Default RE: Please Help...car keeps dying
HOW TO DO IT:
How to do it
1. Disconnect the battery's negative terminal to reset/clear the computer's memory. Leave it disconnected for 30 minutes. WARNING: Whenever removing your battery cables ALWAYS disconnect the negative battery cable first and reconnect it last. Otherwise you could destroy your computer or cause a battery explosion.
2. Disconnect the plug going to your idle motor which is located on the front of your throttle body.
3. Reconnect your battery's negative terminal.
4. Start the engine, and set the idle to the rpm you want with the stop screw on the bottom of the throttle body.
5. Turn off the engine.
6. Reconnect the plug on the idle motor
7. Make sure all accesories (radio, blower motor, a/c, lights, etc) are off and start the engine.
8. Let engine run for two minutes.
9. Turn engine off and wait two minutes then restart engine and let idle for two minutes with all accesories on.
Texas5.0 is offline
Old 05-01-2008, 01:35 AM
9165pt0
9165pt0's Avatar
ok i played with the stop screw and bumped up the idle a lil bit.I still have some adjusting to do. But It isnt dying anymore, is idles at about 1500rpm but it actually idles.
9165pt0 is offline
svfetter
10-05-2015 11:39 AM
guitarman376
09-30-2015 05:54 PM
StalkerGT
09-25-2015 02:41 PM
kachuy10
09-22-2015 01:27 PM
Sminemann
09-17-2015 09:24 AM
Quick Reply: Please Help...car keeps dying
