Please Help...car keeps dying
Hey guys i need some advice, i dont know whats wrong with my car. When i fire it up it just dies out. Even when im ata light I have to keep it revved up so it wont die out. Ive had underdrive pulleys on it and thought maybe the altnernater was going bad. I had the alternater checked and its fine, so i put the stock pulley back on, thinking it would work. Now its still dying out the same way, i have no idea what to check?
RE: Please Help...car keeps dying
ok i tried to clean it out as much as i could (dont have any carb cleaner till the mornin) and it still dies out. Then i found my old throttle body andiac which used to work fine. So i put that iac on and it still dies out right away. The only way it stays on is if im on the throttle...I will get some carb cleaner in the morning and really clean it and try again.
how do i do dis koer test?
ok guys i got some throttle body/intake cleaner and cleaned the iac and throttle body. Now it dies even faster, once i fire it up and try to rev it to keep it on it just lags and doesnt even rev. Please help, what should i look at?
ok guys i had to put more gas in it and it fired up. but the it still struggles and dies at idle unless i rev it. and when the idle drops really low and i rev it, it seems to misfire and then rev up. the iac has been cleaned and changed, i have checked for vaccum leaks. What else could it be?
