wanting to go 10.50s on motor
RE: wanting to go 10.50s on motor
ORIGINAL: AdderMk2
your wallet will be the limiting factor... 4g's isnt enough to run 10's
ORIGINAL: WyDoPn
i plan on having a machine shop do the work im not that mechanically inclined however i do think that 4gs would do it i can get a 351w block for like 300 or cheaper strorker kit for less than thousand get machine shop do its deal ill order sum afrs and i can take it from there,... or atleast i think anyways i really dont know bout this build will motor mounts line up on tublar k member?? wat common probs r with this install??
yea well i wanna run 10s on the motor w.o a doubt even if i gotta save some more its not like i got the car taged or anything yet so i guess well see wat is a realistic number then if your sayin 4 aint enough??
start with about 10-15 and work from there.... 4 aint gonna get you anywhere.
4g's might MIGHT cover chassis and suspension... keep in mind that you will NEED a spec'ed cage for 10.99 and faster... along with all sorts of other stuff
ORIGINAL: AdderMk2
SFI balancer AND flywheel/flexplate. $500.00
3 layer Fire Suit, Window Net, Cage, Transmission shield,Scattershield or flexplate shield. $2500.00
Look on your friends faces the first time you run a 9. PRICELESS!!!!
Good Luck with your car.
I agree about the cash thing.
10-15G'scan get you there, if you buy only go fast parts and forgo the Bling.
Don't forget about maintaining this beast, running this hard costs.$$$$
"Speed costs money, how fast you wanna go?"
[IMG]local://upfiles/95778/C259A0C4F8464D829241EBEBE3241833.jpg[/IMG]
yea i jus dont know i wanna build a 10 sec on motor car you all say 15gs i see a 351w bored to a 400 sumthin on ebay by nascar shop turnkey for 8 i jus dont know i want something radical fo sho just dont know..
you know you can acheive your goal with a major power adder. a 351w with twin turbos will give you reliable 650hp on a stock block. me and my buddy made that setup for less then 4gs.
having the HP to run 10's, and being allowed to do so, are two completey different things...
and if you continue to believe that you can do it... you are just as ignorant as every ricer that thinks his fartcan adds 50hp
