i need help from the 86 50 guys
Old 04-29-2008, 02:29 AM
86302gt
86302gt's Avatar
Default i need help from the 86 50 guys
Ok so i was talking to this guy i now and i told him about how the 86 50 has flat top pistons and that you can not do a bigger cam or heads because the pistons would hit the valves because they do not have valve relief. He told me that i could run TFTW heads and a TF cam and it should not hit The pistons or valves is this so or do i still have to change my pistons to run bigger heads and or cam
86302gt is offline
Old 04-29-2008, 07:13 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: i need help from the 86 50 guys
ptv has nothing to do with valve lift[&:]..but yes it is a good idea on an 86 to run tfs head as they have canted valves not inline....and cam choices for you are limited to certain ones not because of possible ptv probs but more so cause your speed density
mjr46 is offline
Old 04-29-2008, 01:40 PM
86GT 93LX
86GT 93LX's Avatar
a cam affects vacum. speed density reads off of vacum.theres alot of rumors on the 86 motor, ive been thru alot of them.i geuss e7 heads will work on a 86 block. and the e7 has a better flow supposedly compared to the e6 heads. trick flow tw are spendy new. in my opinion you can get your motor redone up nicely with updated pistons for the price of those heads and make the same power.
86GT 93LX is offline
Old 04-29-2008, 01:58 PM
86302gt
86302gt's Avatar
i am maf i converted it was like the first thing i did i have a 91gt computer i think it is a a9l so do i still have a small cam choices . i just dont want to buy a bunch of stuff for it not to work and then have ptv thats y i was going to get the tf top end kit and i just dont want ptv prob if i get the tf top end kit i just wont to put it on and go no problems you no what i mean guys
86302gt is offline
Old 04-29-2008, 02:10 PM
mjr46
mjr46's Avatar
ORIGINAL: 86302gt
but the tfe kit with stage 1 cam and make sure you clay the pistons and check clearance ..there is no such thing as bolt on and go without performing proper checks
mjr46 is offline
Old 04-29-2008, 02:11 PM
mjr46
mjr46's Avatar
ORIGINAL: 86GT 93LX
I doubt it...not using stock heads
mjr46 is offline
Old 04-29-2008, 02:14 PM
86302gt
86302gt's Avatar
ORIGINAL: mjr46
ORIGINAL: 86302gt
thanks man like alwas so i should not have any prob with things hitting but just to make shure i should clay the pistons and see if things r hitting and if not then i am as good as gold right
86302gt is offline
Old 04-29-2008, 03:24 PM
86GT 93LX
86GT 93LX's Avatar
ORIGINAL: mjr46
ORIGINAL: 86GT 93LX
well this assuming the engine has been bored out to like a 306 and heads lightly massaged:P but yeah mjr46 i know what u mean
Old 04-29-2008, 03:30 PM
86 5.0L
86 5.0L's Avatar
i probably just pick out a 5.0 out of a latemodel explorer and stuff it in there,
oh if you think your up to the task you can flycut your pistons Isky has a tool for that, seems like it would be a great alternative
86 5.0L is offline
Old 04-29-2008, 03:46 PM
86302gt
86302gt's Avatar
ORIGINAL: 86 5.0L
ya thats what i was trying to get away from i dont want to have to do that
86302gt is offline
Quick Reply: i need help from the 86 50 guys
