Over Heating.
RE: Over Heating.
I dont think its working right, but when i tested it to see what its running at i didnt use the therm for that reason. i do think i need a new therm. but is thieranything i can do to lower it from 220 to 180??
RE: Over Heating.
replace the therm. its not working right so if its not opening all the way your car will continuously run hot especially if rad, water pump and fan is working properly and you've flushed everything. its yours therm. have you verified everything is in working order and clean?
RE: Over Heating.
I have heard of these water additives which are designed to lower the water temp by around 30 deg. I'm on the lookout for them in the shopsto see if they work.
'Water Wetter'
http://www.jegs.com/p/Red+Line+Oil/752191/10002/-1/10121
and
'Royal Purple'
http://www.jegs.com/p/Royal+Purple/747921/10002/-1/10121
'Water Wetter'
and
'Royal Purple'
