347 Stroker with Original Heads
Old 04-30-2008, 09:09 AM
radiochris123
radiochris123's Avatar
Default 347 Stroker with Original Heads
Question. I've got a '91 5.0 I rebuilding. I did up the bottom end, Bored, stroked (347), ect. ran out of money and just need to get it back running. What do you guys thing about putting the original heads back on? also should I use the same cam or go bigger?
Thanks,
radiochris123
radiochris123 is offline
Old 04-30-2008, 09:16 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 347 Stroker with Original Heads
ORIGINAL: radiochris123
Thanks,
radiochris123
[:'(][:'(][:'(][:'(][:'(][:'(]...anymore questions!!!.....waste of time and you'd be choking the motor out
mjr46 is offline
Old 04-30-2008, 09:31 AM
1fast86
1fast86's Avatar
ORIGINAL: mjr46
Thanks,
radiochris123
Absolutely will choke the motor, use AFR 185or equivalent head. I would go with a Comp Cam grind something around .550 lift. Good luck with the motor.
1fast86 is offline
Old 04-30-2008, 09:45 AM
radiochris123
What do you mean by choking? I know I won't get the most out of the engine, but will it work? Thank you much.
Old 04-30-2008, 09:46 AM
Joel5.0
Joel5.0's Avatar
Since you're limited by the always present financial condition, it's really your call. You shouldn't obviously expect "great things" out of a 347 with E7 or equiv. heads, but that's what you can do right now. You have the foundation ready, it's a matter of planning and saving for a good set of heads to complement the stroker. Would it be "wise" to add to the cost with a "bigger" cam?...... your call, but gains would not be at the level you could be expecting. If you look at it in terms of $'s and ¢'s...... you're basically ~$1,800 (+ miscellaneous) away from a killer setup.
Joel5.0 is offline
Old 04-30-2008, 10:16 AM
AdderMk2
Banned
AdderMk2's Avatar
if you put E7 heads back onto the 347... expect about 100hp less than you COULD be making
AdderMk2 is offline
Old 04-30-2008, 10:36 AM
radiochris123
Thanks Joel5.0 That's what I wanted to know. I figured I can get it running and change heads, cam, ect later.
Old 04-30-2008, 10:40 AM
w8less
w8less's Avatar
yep you can do it i had to do the same thing. the car was still very strong but wasnt to its full potiental
w8less is offline
Old 04-30-2008, 01:17 PM
5spd GT
5spd GT's Avatar
If that is all you can afford right now and need it running, go for it.
You can always add the top-end later and open it up.
5spd GT is offline
Old 04-30-2008, 01:24 PM
aode08
aode08's Avatar
i just got out the hospital from choking on some E 7's after I seen this thread[:'(]
aode08 is offline
Quick Reply: 347 Stroker with Original Heads
