Mechanic said im screwed
Old 04-30-2008, 09:38 PM
ShelbySVO
ShelbySVO's Avatar
Default RE: Mechanic said im screwed
My bad you were replying to somebody else..thanks for the advise
ShelbySVO is offline
Old 04-30-2008, 09:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I saw your video.......you might wanna try a smaller tire cause you plain just got no more room as a result of the tire and rim choice[:@]
mjr46 is offline
Old 04-30-2008, 09:41 PM
mjr46
mjr46's Avatar
maybe try a 40 series on the front???
mjr46 is offline
Old 04-30-2008, 09:43 PM
ShelbySVO
ShelbySVO's Avatar
This size seems to be a standard size everybody seems to be running on there fox's.I don't get it.
Old 04-30-2008, 09:48 PM
ShelbySVO
ShelbySVO's Avatar
What also is weird is the right side has the clearance and does not rub. I did notice that when the right tire (the one that rubs) is straight the left side is still pointed outwardand is not straight on..
Old 04-30-2008, 09:51 PM
mjr46
mjr46's Avatar
same size tires often vary between maufactorers...often times two 245/45/17 or vice versa side by side from different manufactorers will be visibly shorter or taller than one another[:@]
mjr46 is offline
Old 04-30-2008, 10:48 PM
silver91gt
silver91gt's Avatar
put them on the back and do a bunch of burnouts, then put them back on the front.
silver91gt is offline
Old 04-30-2008, 10:52 PM
crusin92red5.0
crusin92red5.0's Avatar
do you have caster/camber plates? nice paint job!
crusin92red5.0 is offline
Old 04-30-2008, 11:46 PM
raven_ghostwolf
raven_ghostwolf's Avatar
89 LX that is why they are rubbing on the front. Lets see the first thing everyone will tell you is you need the fenders off a 91 - 93 because they have a 1" wider opening at the point where your rub is.
Get under the car and look at the fiberglass fender extensions and see how much distance there is from the edge of them to the edge of the metal part of the fender. Then IF you can find one take a look at a 91 - 93 LX then make your own logical conclusion. Is all I will say on this subject.
PS I am running the 245/45 - 17's on my 87 no rub!
raven_ghostwolf is offline
Old 05-01-2008, 02:42 AM
PJC Racing
PJC Racing's Avatar
ORIGINAL: raven_ghostwolf
Exactly.
PJC Racing is offline
Quick Reply: Mechanic said im screwed
