need help with occasional rpm drop
Old 04-30-2008, 05:49 PM
88fox50
88fox50's Avatar
Default need help with occasional rpm drop
sometimes when returning to idle while driving the engine drops from 1000 rpm down to about 500 along with the voltage ..then back up repeatedly... ...sometimes it runs great then sometimes it hesitates in lower rpms and sorta pops like an internal backfire but i get pissed and mash the throttle and it returns to normal... i have replaced plugs, wires, cap rotor, new msd blaster 2 coil be here tomorrow, replaced EGR, still doing it ...any ideas?? oh and replaced fuel filter...
1988 5.0 GT
M/T
88fox50 is offline
Old 04-30-2008, 06:00 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: need help with occasional rpm drop
Try cleaning the iac and the throttle body.
PRO50SC is offline
Old 04-30-2008, 06:22 PM
brentloftis
brentloftis's Avatar
Check or replace the vac line from below the upper intake plenum to the MAP sensor.
brentloftis is offline
Old 04-30-2008, 06:29 PM
Joel5.0
Joel5.0's Avatar
Is it a MAF conversion?.... if so, did you install and wire the VSS sensor?
Joel5.0 is offline
Old 04-30-2008, 06:44 PM
88fox50
88fox50's Avatar
ok i googled and looked thru the haynes book...i will replace the IAC tomorrow (52.00) and i will let u know...but as far as the MAP sensor hose..is there anyway to replace the hose without pulling the intake off? because the hose is definatly in need of replacing..its not cracked but it is dry rotting ....thanks for your help and patience
88fox50 is offline
Old 04-30-2008, 07:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
voltage will drop as rpm drops cause the alt output is based on rpm so I wouldn't focus to much on that issue more so the idle issue... after cleaning throttle body and iac..has the car been tuned up lately.
mjr46 is offline
Old 04-30-2008, 08:10 PM
88fox50
88fox50's Avatar
ORIGINAL: mjr46
i bought it 2 weeks ago....since then i have replaced the cap, rotor, plugs, wires, fuel filter, coil....c'mon man...gimme some credit.
88fox50 is offline
Old 04-30-2008, 08:15 PM
mjr46
mjr46's Avatar
ORIGINAL: 88fox50
ORIGINAL: mjr46
how am I suppose to know you have done all that stuff??.........anyway check for vaccum leaks and run a loeo/koer test and verify there are no codes
mjr46 is offline
Old 04-30-2008, 08:19 PM
88fox50
88fox50's Avatar
just messin with ya man!...lol ....anyways i appriciate the info...
88fox50 is offline
Old 04-30-2008, 11:43 PM
brentloftis
To replace the hose you only need to remove the upper plenum, and most of the time not all the way off, just enough to get access.
Quick Reply: need help with occasional rpm drop
