NO SPARK
Old 04-30-2008, 10:14 PM
whitestang86
whitestang86's Avatar
Default NO SPARK
Can anybody tell me if the TFI, Ignition module, Control module, whatever you wanna call it on the distributor goes bad will this cause no spark?
whitestang86 is offline
Old 04-30-2008, 10:36 PM
jwog666
jwog666's Avatar
Default RE: NO SPARK
it the tfi goes bad you will have no spark
jwog666 is offline
Old 04-30-2008, 10:39 PM
94StinkinLincoln
94StinkinLincoln's Avatar
ir can yes, is it mainly when the engine is hot?
if not...then its more than likely, but not always, the dizzy or coil.
pull the coil connector, hook a test light up, crank car, does it blink?
94StinkinLincoln is offline
Old 04-30-2008, 11:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: whitestang86
alot of things can cause no spark...like no power to coil, bad coil, bad cap and or rotor or coil wire, bad tfi module, bad stator in dizzy, faulty output command from ecm..ect ect......you'll need to verify the basics like power to coil, and having a test light and an inline spark checker are very useful in such situations
mjr46 is offline
Old 04-30-2008, 11:35 PM
whitestang86
there is a 22k resistor that goes to this TFI that was accidentally cut and hard wiredwithout this and a full 12v signal was sent to the TFI, I'm sure this destroyed it?? I've rebuilt this motor, tryin to start it for the first time, so its not an issue of getting hot. I seem to get power to the coil, had an inline spark checker and not a thing. i'm gonna replace the TFI and see what happens
Dathan
10-05-2015 05:52 AM
dalehunter
09-25-2015 10:51 AM
lmurf60
09-24-2015 10:07 PM
stangin1996gt
09-21-2015 11:01 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: NO SPARK
