Installing temperature sender.
Old 05-01-2008, 01:52 AM
90notchLF
90notchLF's Avatar
Default Installing temperature sender.
My temperature guage isn't working so Im guesing it's either the sender or the the thermostat.
Is it difficult toreplace the sender?
90notchLF is offline
Old 05-01-2008, 05:14 AM
9 Sec 93 LX
9 Sec 93 LX's Avatar
Default RE: Installing temperature sender.
ORIGINAL: 90notchLF
No.
The sender is the brass pieceto the right of the distributor in this picture.
Should be in a similar location on your car.
I always recommend you buy the service manual for your car.
Buy the special socket to change it(NAPA).Otherwise you'll crack the new one!
Thermostat has no control over the gauge.
[IMG]local://upfiles/95778/62352BE2EE764B0EB670E5E3012CC600.jpg[/IMG]
9 Sec 93 LX is offline
Old 05-01-2008, 01:50 PM
90notchLF
90notchLF's Avatar
Does thisspecial socket have a name?
Old 05-01-2008, 01:52 PM
brentloftis
brentloftis's Avatar
I used a regular deep socket with mine. I don't recall the size but I took the sender over to the wall and found the right fit in a deep socket and did not have problems.
brentloftis is offline
Old 05-01-2008, 02:01 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
deep well socket to install adapter. teflon take on adapter and sending unit itself. i think its either 11/16ths or 9/16th deep well if i remember correctly. then a 1/2 inch open ended wrench to tighten the sending unit into the adapter.
FivePointOhh is offline
Old 05-01-2008, 04:49 PM
90notchLF
90notchLF's Avatar
Got it, thanks.
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Installing temperature sender.
