Rear seal on trans
Old 05-01-2008, 03:10 PM
southern4life_99
southern4life_99's Avatar
Default Rear seal on trans
Hey just a quick question, I finally got my AOD today and the dude I got it from said I should replace the rear seal in it. How do I go about doing that? Also I am assuming this is the seal i need: http://www.partsamerica.com/productd...68&PTSet=A thanks everyonefor all the help during this project.
southern4life_99 is offline
Old 05-01-2008, 05:32 PM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: Rear seal on trans
rear main seal
its best to do it while the trannies out otherwise u may have him do all this work and ur car may leak oil everywhere
93 LX FiveO is offline
Old 05-01-2008, 07:02 PM
southern4life_99
yea i was gonna replace the main seal on the motor too but dude i bought the tranny from said i should replace the rear seal in the tranny too. I am installing the tranny myself. How do i replace that?
Old 05-01-2008, 07:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: southern4life_99
remove driveshaft using a 12mm 12pt wrench = 4 bolts at rear...pull drive shaft out...pry seal out and tap new one in and reinstall driveshaft and bolts
mjr46 is offline
Old 05-02-2008, 05:22 PM
southern4life_99
cool, so basicly the same as with the crank rear seal
Old 05-02-2008, 05:43 PM
1fast86
1fast86's Avatar
ORIGINAL: mjr46
Pretty easy job, it is easier if you do it before you install the trans and you wont get a lot af trans fluid everywhere.
1fast86 is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
67LimeCoupe
09-30-2015 04:46 PM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Rear seal on trans
