Are my casters adjustable?
1989 lx 5.0 pretty much stock suspension. Are the casters adjustablefor the front tires? . I was told they are not. I was also to if you put new caster/camber set up on the car to adjust the wheel position of the tire within the wheel well that the car will then pull really bad to one side. I think the guy that told me this had no clue what he was taking about. Also if the casters are adjustable how do you go about adjusting them...Thanks
RE: Are my casters adjustable?
OK, first off it's caster not casters. On the stock set up, it is somewhat adjustable. However to utilize the full movement that can be had, caster camber plates will allow a lot more movement. The adjustment has to be done while on an alignment machine. This is not a do at home project. The caster camber plates can be installed at home, but the car still needs to go for alignment.
