Rocker Studs Torque
Old 05-02-2008, 01:45 PM
jerod187
jerod187's Avatar
Default Rocker Studs Torque
Hey how much should i torque my rocker studs to? because i did 35 ibs before and they came undone?
jerod187 is offline
Old 05-02-2008, 01:49 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Rocker Studs Torque
you have been here for a while.... one would think that you would know enough to check the tech articles...
https://mustangforums.com/m_4109492/tm.htm
AdderMk2 is offline
Old 05-02-2008, 05:05 PM
jerod187
jerod187's Avatar
ya thats why i did check the tech articels, but its not in three it just says rocker arms, i wanna know the rocker stud torque, that goes into the head
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
jerod187 is offline
Old 05-02-2008, 07:16 PM
AdderMk2
Banned
AdderMk2's Avatar
Rocker arm stud bolts 40-45 ft.-lbs.
i guess you missed something
AdderMk2 is offline
Old 05-02-2008, 07:26 PM
smythge
smythge's Avatar
ORIGINAL: jerod187
Do you want the torque specsfor pedestal mount rockers, or the torque specs for the studs in stud mounted rocker arms?
smythge is offline
Old 05-02-2008, 07:28 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: smythge
ORIGINAL: jerod187
hrm... i wonder
AdderMk2 is offline
jerod187
jerod187's Avatar
ok good thanks, i didnt see it there though because i remember reading 50-55 ibs some were
jerod187 is offline
Old 05-02-2008, 10:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: jerod187
you are correct^^^^^^^^^^^^on most aluminum heads it's 55 ft lbs!!! that's what it is on my afrs and a friends edelbrocks too!!
mjr46 is offline
Sixer4Life
10-12-2015 04:26 AM
guitarman376
09-30-2015 05:54 PM
uedlose
09-30-2015 08:01 AM
wraith777
09-28-2015 10:49 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Rocker Studs Torque
