heads question
RE: heads question
ORIGINAL: FredP
ok right now i got gt40x aluminum heads, my question is would i benefit if i switched to afr165's?
my application is b-303 cam and cobra intake
or should i do a whole new combo?
RE: heads question
The GT-40 X303's over the years of bench Flow testing actually have been shown to Flow about the same or bit better than AFR165's. The avg flow rates over the entire range of valve lift that is. You would see little to no gain switching to the 165's unless you had some port work done to them. If you want better performance out of the X303's as they are, toss out that FRPP Alphabet Cam and get something better. I highly reccomend the Anderson Ford Motorsports(AFM) N-41 Cam, it is the most optimal and designed specifically for the X303's and GT40(Cobra) intakes.
RE: heads question
ORIGINAL: FredP
where would you recommend getting a custom cam at and estimate of price? oh yea and my goals are to get a little over 250rwhp and break 13.2
RE: heads question
ORIGINAL: mjr46
the anderson cams are almost as outdated as the alphabet cams are......the best bet for max combo potential would be have a custom cam designed
But for an OTS(off the shelf) Cam the N-41 is pretty much the best your gunna get with the non-ported GT40X's and a Cobra intake combo as far as a "streetability vs perfomance" balance goes. Or at least in my experiance anyway. I also like the TFS Stage 1 for an OTS Cam for that combo but you loose a bit of bottom end torque with it.
Custom grind... hell ya, Jay or Rick are both wizards and you can't go wrong with either of them.
