car idleing bad, pulled codes
Old 05-04-2008, 05:05 PM
primetime5.0
primetime5.0's Avatar
Default car idleing bad, pulled codes
21-ECT out of self test range 0.3 to 3.7 volts.
34-PFE or EVP circuit above the closed limit of 0.67 volts,PFE or EVP circuit has intermittently failed above the closed limit of 0.67 volts.
44-Thermactor Air Injection system inoperative (Right side).
94-Thermactor Air Injection system inoperative (left side).
those are the codes I got, the only ones im worried about are the first two obviously, the car idles fine for a few minutes then begans to surge really bad then eventually kill itself... any ideas?
primetime5.0 is offline
Old 05-04-2008, 05:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: car idleing bad, pulled codes
when you ran the koer test was it warmed up??? if not that'll explain code 21
mjr46 is offline
Old 05-04-2008, 05:12 PM
primetime5.0
as warmed up as it was going to get before it dies on its own
Old 05-04-2008, 05:15 PM
mjr46
mjr46's Avatar
ORIGINAL: primetime5.0
it has to reach closed loop I believe or it'll flag that code if koer is run
mjr46 is offline
Old 05-04-2008, 05:16 PM
primetime5.0
and the only koeo code that caught my eye was 67- neutral safety circuit failure
mjr46
mjr46's Avatar
the evp code is the egr valve position sensor..do you still have egr on yours??
mjr46 is offline
Old 05-04-2008, 05:20 PM
primetime5.0
kinda I took off the part where it plugs into then glued the plunger half way down to make the car think its working
Old 05-04-2008, 05:30 PM
primetime5.0
alright I just did it with the car at normal temp, code 21 went away but code 31 popped up PFE or EVP circuit below minimum voltage of 0.24 volts.
Old 05-04-2008, 06:07 PM
aode08
aode08's Avatar
aode08 is offline
Old 05-04-2008, 06:45 PM
primetime5.0
ORIGINAL: aode08
I know but it works great!
Quick Reply: car idleing bad, pulled codes
