Fox 5.0 now stalls after installing catted H pipe
I swapped the off road h pipe for a catted h pipe on my fox & now the car stalls when idling. It doesn't stall every time, but it has quite a few times and we're not even 24 hrs since the swap. What couldbe the issue? My guess is clogged cats maybe.
RE: Fox 5.0 now stalls after installing catted H pipe
Does it idle okay when it does? If not get a socket and adjust your air idle screw, located under your throtle body. If you adjust it only turn half a turn or do it while its idling.
