water pump question
RE: water pump question
ORIGINAL: GaryBisiniere
ya but does any1 know what year they spin reverse of stock 87-93 because i dont have a brackter like that for my alternator...and i need a new pump.
any1?
any1?
If you get a standard rotation water pump, you will have to get a new WP pulley to match. Or you can convert to a V-belt system...
or do it the easy way.. buy one of these...
http://store.summitracing.com/partde...p;autoview=sku
ORIGINAL: 93 LX FiveO
custom bracket/tensioner = $$$
IMO id want more of the belt grabbing than barely rubbing
i have got over 400 miles on the motor like this without ANY problems. This was actually recommended to me by a VERY reputable race shop...
and you dont need a custom bracket... just need to take your face off the bong every now and then, and look around
ya that made sense...watever adder.
see u at NED if u actually drive ur car there.. and make it home..
ur cobra was like .5 second faster than my old fox and had like 70 more horse... ill really listen to u on setups
you had gears... dick.
If you REALLY wanna run against me. I'd be more than happy to oblige!
If you don't hit anything again... that is!
Isn't there a way that you can clock or flip the tensioner or something like that? So instead of pushing the belt down to create tension, it pulls it up toward the hood to do it? If that is an option you can do it how Adder has it but it would be grabbing the waterpump more. I don't know if you can do that but it seems like I saw something like that somewhere.
adder i bought one of those alternator kits off my buddy. he said to run a v belt system i need a new water pump that spins in opposite direction. he also said i can get it from a local parts store from an older mustang that spins the right way. so my question is what year?
thanks
thanks
if you have the alternator kit that i linked, you can use your stock pump without any problems.
IF YOU CONVERT TO AN OLDER STYLE STANDARD ROTATION PUMP YOU NEED TO GET A V BELT SYSTEM. I do not know of any companies that make a serpentine style ribbed water pump pulley
