306 stroker question?
RE: 306 stroker question?
ORIGINAL: FASTBLACK
Probe is descent i guess. Are you saying you already have a 306 because a 306 is not a stroker. It's just a 302 bored .030
ORIGINAL: 5spd GT
It is not considered a stroker, unless the stroke is changed.
A long rod 306 typically has a 5.40" rod and a shorter compression height piston.
ORIGINAL: djcondo
my 5.0 has 145xxx on it and i was going to start off by rebuilding the bottom end of the block. my question is if anyone has ever herd of Probe industries stroker kits and if they are good.
Probe .040 pistons, block bored and honed .040, pistons balanced and pressed like the old ones.
Trickflow or Eldelbrock Intake.
You should make at least 300rwhp with some decent heads, thats alot of power in a fox with massive torque and your ET will greatly reduce.
THR Made 339 NA RWHP with this setup and massive torque, added with 4:10,s it went 12's.
Hi Comp 306 with ,TFS Heads,Holley Systemax intake, Comp 282 HR Cam, Long Tubes, MSD 6AL2, MSD HVC 2 coil, JLT CAI, C&L MAF.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
