FRPP Valve Covers...possible fitment issues
Old 05-06-2008, 12:26 PM
elite130
elite130's Avatar
Default FRPP Valve Covers...possible fitment issues
I have the motor out of the car right now and it's going to begetting a good cleaning and paint job. I have had my eyes on the FRPP Valve Covers that are black with silver fins on them and have the Mustang lettering on them (see them HERE). I really want to get these for the motor, but before I spend $150 on them, I want to make sure they will work with my future plans.
A couple questions before I purchase them:
1) will I need an intake spacer using stock heads and intake? If yes, how thick do I need?
2) when I upgrade to AFR or TF heads, will these valve covers clear the 1.6 or 1.7 rockers?
Thanks for the help!
elite130 is offline
Old 05-06-2008, 12:51 PM
nseoi
nseoi's Avatar
Default RE: FRPP Valve Covers...possible fitment issues
i have similar ones with ford racing on them and they fit fine under the stock intake plenum. you should only have to worry if you are using a larger intake, if so, which one?
nseoi is offline
Old 05-06-2008, 02:47 PM
shaun8850
shaun8850's Avatar
i had those same ones on my stock heads... the throttle plate bracket rubbed the top of them, had to eye out the bracket holes Prolly due to TFS intake...later i put TFS heads on and they wouldnt clear the stud mounted rocker arms, I think it was because of the oil baffle inside the cover. I ditched them and bought TFS valve covers, TFS covers have to be drilled to put in oil fill tube
I have 1.6 rockers btw
http://img353.imageshack.us/img353/9...5214090ou6.jpg
shaun8850 is offline
Old 05-06-2008, 08:57 PM
cleanfitty
cleanfitty's Avatar
They won't clear a cobra intake, the linkage will bind bady.
cleanfitty is offline
Old 05-06-2008, 09:27 PM
1991LX5.0
1991LX5.0's Avatar
They cleared my big rockers without any problems and they fit nicely under my track heat intake with a 3/8 spacer plus they look great
1991LX5.0 is offline
Old 05-06-2008, 09:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'll be fine and when you upgrade in the future just buy a 3/8 spacer and you can buy extra thick valve cover gaskets if rockers pose a clearance issue
mjr46 is offline
Old 05-07-2008, 08:44 AM
elite130
elite130's Avatar
Thanks guys for the help!
My ultimate goal is to get either AFR's or TrickFlow heads with a Trickflow intake and run 1.6 or 1.7RR's.
Thanks 1991LX5.0 for the pic, that is the exact setup that I am planning on doing on my car.
elite130 is offline
Nick Oliver
10-17-2018 04:22 AM
Ipaman
09-22-2015 07:01 AM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: FRPP Valve Covers...possible fitment issues
