Drop springs
Old 05-06-2008, 03:51 PM
Duspan
Duspan's Avatar
Default Drop springs
I am considering getting a set of springs to lower the car a little bit. Any of you guys have any suggestions? How bad would the ride be after install? Thanks.
Duspan is offline
Old 05-06-2008, 07:10 PM
1.9.9.4 pony
1.9.9.4 pony's Avatar
Default RE: Drop springs
it wouldn't be bad unless u have a bummpy road all over the place and pretty much i think it will knock u down 3-4hp since ur putting the weight of the car closer but thats about all it will do and make sure if u do that set up its just not springs also think about getting some good shocks and a new pair of bushings best place is ebay i think get the hole kit
1.9.9.4 pony is offline
Old 05-06-2008, 07:18 PM
Foxbodyforever
Foxbodyforever's Avatar
I've got the ford racing "B" springs and i'm pretty happy with em, the ride is definately harder but i think it makes driving more fun, plus the car is lower, looks better, and you can put some more power to the ground
Foxbodyforever is offline
Old 05-06-2008, 07:32 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
ORIGINAL: 1.9.9.4 pony
Won't happen. IF anything was to happen you would gain bc when you drop the car down it straightens the angle of the driveshaft so there is less of a strain in the drivetrain but you wouldn't see any dyno numbers or fell it. Alot of people use 4 cyl springs to srop there car some and still retain a stock ride. Remember if you drop too much (around 1.5 or so is what I here the rule of thumb is) you will ne CC plates and a bumpsteer kit to help keep that ride even better.
projectresto83 is offline
Old 05-06-2008, 07:34 PM
tw3ak
tw3ak's Avatar
Ford C Springs FTW! They ride like a charm.
tw3ak is offline
Old 05-06-2008, 07:39 PM
projectresto83
M.A.D. Motorsports
How much did the C's drop you??
Old 05-06-2008, 08:39 PM
stang8689
stang8689's Avatar
I like Eibach Sportlines, but i'm more into handling
stang8689 is offline
Old 05-06-2008, 08:59 PM
tw3ak
tw3ak's Avatar
ORIGINAL: projectresto83
Quite a bit actually. My front end use to sit REAL high and raise way higher whenI got on it. I would say probably 2 1/2 - 3in. Probably closer to 2 1/2in. If you look at my car domain you can see before and after pics. It use to sit real high and ride like crap. Now it sits nice and drives like a dream compared to what it was before.
tw3ak is offline
Old 05-07-2008, 01:40 PM
Duspan
Duspan's Avatar
Thanks for the input, I think 1.5 in. would do me I dont want to drag the frame you know. What do you guys run for shocks? I am interested in getting a decent drop and gain some handling without getting to rough.
Duspan is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Drop springs
