Gear ratio's
Old 05-07-2008, 11:43 AM
sYckmYnded
I ♥ Acer
sYckmYnded's Avatar
Default Gear ratio's
what would be the best rear gear set for a 1/4 car with a fully built 3 speed C4 i want the fastest 1/4 mile time but i fear if i go to high in the ratio ill lose all top end speed for the big end of the track, any advice?
sYckmYnded is offline
Old 05-07-2008, 12:26 PM
1990NOS!
1990NOS!'s Avatar
Default RE: Gear ratio's
in my buddy's car he has 4.10's... he runs 9.6's going through the traps at 140+mph @ almost 8200rpms.... (yeah its a built motor obviously)....A c4's gr'ing is nice though...atleast in mine it is... 1st is kinda short-right out the hole- 2nd nice mid range- 3rd i'm wide open... and i'm about to go to 4.30's.... i run 1/8th mile though.....
1990NOS! is offline
Old 05-07-2008, 01:13 PM
sYckmYnded
I ♥ Acer
sYckmYnded's Avatar
the gears in there now are 3:73 and the car is crazy fast, but if i go to a 4:10 im scared ill get to high in the rpms at the end of the track i serisouly doubt i can turn 8k saftly since i barly push it to 6500 it falls out about there
Old 05-07-2008, 01:22 PM
1990NOS!
1990NOS!'s Avatar
nah you wont hit 8500 rpms.... the way he does it is a built motor... Dart Man O war aluminum block, AFR heads, 850 carb, lots n20.. and a solid roller cam... and other tweaks and tunes in there as well....
what kinda suspension, tires, and weight reduction do you have now?
Have you ever ran it in a 1/4?
If so what rpm were you at at the finish?
1990NOS! is offline
Old 05-07-2008, 01:25 PM
WhiteWindsor
WhiteWindsor's Avatar
If when you change you have too much gear then go with a taller tire.
WhiteWindsor is offline
Old 05-07-2008, 01:29 PM
1990NOS!
1990NOS!'s Avatar
Faster mph--- take longer to rotate a taller tire---- its a just science....sYckmYnded, but if you're runnig a26x 10.5 no need tomini tub... a 28x10.5--- then you'll need a mini tub...
1990NOS! is offline
Old 05-07-2008, 01:31 PM
1fast86
1fast86's Avatar
ORIGINAL: 1990NOS!
That is the only way to tell what gears you need time slip, rpm at traps, and tire size. If you really want to get technical with it putthe caron a dyno and find out where in the rpmpower falls off and try to make that your target RPM at the finish line.
1fast86 is offline
Old 05-07-2008, 01:52 PM
1990NOS!
1990NOS!'s Avatar
sYckm- When you say fully built 306... what is the compression ratio????
In a 306, with a nice set of heads, and like 10:0:1 comp.... with a nice bump stick... some n20 will help a lot with getting you to the finish a little faster... of course any P'adder will...
just a thought.... but if you are going n/a... some gear, less weight, suspension, good tires, a nice tune, and good driving will do the trick.... you want to be the shft to come on or about to come one at the finish line.... What size stall converter do you have???
1990NOS! is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Gear ratio's
