no sound from speakers
Old 05-07-2008, 03:08 PM
Stangnsnow2
Stangnsnow2's Avatar
Default no sound from speakers
i just wired in a CD player in my msutnag again...i had to run new speaker wires and i ran the battery remote and ground to the cars existing wires...now all the sudden the speakers stoped working...the subwoofers work but the speakers arent...any idea what this might be?
i had this happen to me in my old mustang too and i think it might be the cd player but im just looking to see if there is something else im missing
Stangnsnow2 is offline
Old 05-07-2008, 03:16 PM
PJB
PJB's Avatar
Default RE: no sound from speakers
Theres probably a bad connection.
Unplug all the speaker wires and plug one set in. If it works, plug another set in. Keep doing that until they dont work again.
Seeing that you replaced all the wires the factory amp isnt the issue here so Im betting on a wiring issue. Its happened to me before.
PJB is offline
Old 05-07-2008, 03:41 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
check all connections. from the back of the deck to the speaker. check them all
FivePointOhh is offline
Old 05-07-2008, 03:47 PM
brentloftis
brentloftis's Avatar
Change the rear speaker wires to the front speaker wires to see if it is wiring or the unit it self. I have seen a lot of people blow the rear channels out by hooking up their amps to a [+ & -] spice into the rear speaker wires.
brentloftis is offline
Old 05-07-2008, 05:53 PM
sultan68
sultan68's Avatar
if there's a bad speaker it could cause all of them to not work
my electronics teacher explained it to me but i dont remember how it works
it doesnt make sense to me but i guess
sultan68 is offline
Old 05-07-2008, 07:29 PM
ttocs
ttocs's Avatar
check us out on the audio forum next time. When a deck has a shorted speaker it will often turn off the decks amp to keep from smoking it. When it does this the pre-amp will remain on which is what it driving your sub amp. Check all your connections and see if there are any places that are shorting. If you don't see any try disconecting one speaker at a time from the deck, with the deck on to see if it will come back on when you disconnect the one that is shorted.
ttocs is offline
Old 05-07-2008, 08:32 PM
Stangnsnow2
thanks guys, the front driversside speaker came off and it shorted the whole things...i was starting to think it was the ford amp under the dash or the cd player but i got it working now...
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: no sound from speakers
