87-93 Under Dash Wiring Harness - MustangForums.com
Old 05-07-2008, 06:42 PM   #1
87Stallion
87Stallion's Avatar
Default 87-93 Under Dash Wiring Harness
Are the under dash wiring harnesses all the same for fox bodys? Im wondering if a inside harness from a 4-cyl will work in my GT and does it have to be a 87 like mine?
87Stallion is offline   Reply With Quote
Old 05-07-2008, 07:38 PM   #2
dave1170
Default RE: 87-93 Under Dash Wiring Harness
Some people say they are the same. I've done a few swaps and every time the 4 banger harness would screw up the gauges. When I changed them over with a 5.0 harness everything worked fine. So, IMO, the 4 banger harness will cause problems. The dash harness from a 87-93 5.0 will work fine for you, they are all the same. The engine harnesses were different on certain years. Hope this helped!
dave1170 is offline   Reply With Quote
Old 05-07-2008, 07:54 PM   #3
87Stallion
87Stallion's Avatar
Was that because you had 4 banger guages? Just wondering if it would work on a 5.0 with original 5.0 guages. My thinking is the harness itself should be the same. Just wanted to ask before I try it. I have looked at several 4-cyl harnesses and I can't find any differences but that doesn't mean that there isn't.
The previous owner butchered the inside harness on my car.
Old 05-07-2008, 08:29 PM   #4
dave1170
That was with the 5.0 gauges installed.
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
1994-1995 ODBII Port Urambo Tauro 5.0L (1979-1995) Mustang 6 10-05-2015 10:37 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
1993, 1994, 50, 87, 8793, dash, diagram, gt, harness, lx, modified, mustang, underdash, wire, wiring
