how big of stall with my set up?
Old 05-08-2008, 08:39 PM
ctgreddy
ctgreddy's Avatar
Default RE: how big of stall with my set up?
i have a custom edge racing converter with a 3k stall and its not hard to drive. only difference i've noticed is it feels slow up until the stall speed. and yeah the car pushes at about 2500. i dont think a 3800 would be all that terrible to drive on the road.
ctgreddy is offline
Old 05-08-2008, 08:42 PM
floodzilla
floodzilla's Avatar
ORIGINAL: ctgreddy
Well i could understand that, the last high stall i had jerked you around all the time, so i got a stock stall, though its my dd. proley the old school tech on it.
floodzilla is offline
Old 05-08-2008, 08:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you should be fine with a 3800.....we're about to put a 3500 in my friends whose I just told you had a 3000 in it.....the 3000 that's in it now is way streetable..you don't even know it has a stall except when you wrap the throttle while cruising downtown
mjr46 is offline
Old 05-08-2008, 08:47 PM
stamper5.0
stamper5.0's Avatar
ok awesome...thanks guys a appreciate it....but if anyone knows anyhting about a non lock up or lock up means LMK
stamper5.0 is offline
Old 05-08-2008, 09:55 PM
94StinkinLincoln
94StinkinLincoln's Avatar
lock up is in aode's and 4r70w's
non lock up is in aod's
lock up refers to mechanical locking inside the converter to achieve a 1:1 direct drive, like a manual clutch and flywheel.
aod's are non locking, so that means, if you have a 3500 stall, and are cruising at 2300rpms, the converter is constantly slipping, the aode's lock the converter and rpms drop some and slippage is very minimal. a good trans cooler is needed for either and the aod will need a real good cooler to keep from killing the trans from excessive heat. a fin type cooler and fan would work great, and get a trans temp guage!
a high stall makes you feel like you have no power at part throttle, like you need to give it more gas to get moving, when u got wot, it really shines. i had a 3500 stall and that was fun, foot braking to 3k, o yea!
there are many variables to converter stall:
weight
rear gears/trans gearing/tire size
engine tq. and rpm profile, like cam/head/intake operating ranges/profiles
n/a, boost, or spray
somewhere around 3k would work, best performance contact either Edge racing or Precision Industries for a custom stall.
94StinkinLincoln is offline
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
popsotto
09-28-2015 06:58 AM
Quick Reply: how big of stall with my set up?
