how big of stall with my set up?
im about to buy a stall converter. i was wondering if u guys could lead me in the right direction. my set up is a 306 with protop line heads...my cam specs are COMP Cams Nitrous HP Camshafts
Camshaft, Hydraulic Roller Tappet, Advertised Duration 274/ 286, Lift .555/ .570at 050 inch lift duration is 224 int./236 exh..i have a stock intake right now. i will be spraying a 100-150 shot but not sure yet. the trans i have is a aod it was rebuilt about 2000 miles ago with a shift kit and a cheap 2800 stall. after spraying nitrous from a dead dig i guess i "ballooned up" the stall. im not sure but i think i might get a TCI stall. i called they said the would have to custom make it...i want it to be a 3500 stall with an anti ballooning plate. but im not sure.......any help would be greatly appreciated. the sooner i kno wat to get the sooner i can order it
thanks jeff
thanks jeff
RE: how big of stall with my set up?
i thought about it...but some of my friends say thats too big...b.c i drive it on the street still...but does anyone kno anything about the anit ballooning plate? and should i get a non lock up? or lock up?. im not sure what that means
they're wrong!! expecially if you go with TCI.......their advertised flash stall is a lot higher than actual flash!! Friend has a 3000 that starts to flash at 2400...we can never get 3000 before it literally pushes the car
sorry but i got a similar question. my t5 blew and i got the aodand bought a 2500 stall converter. i was woundering what kind of flywheel do i need to get for it? new to autos. btw how much hp are you pushing jeff?
ORIGINAL: stamper5.0
well if i go 3800...should i get a line lock? or just TRY and foot brake it?
i had just a stock flywheel with my 2800 stall. and idk how much hp im pushing never been on the dyno...i was thinking with a 150 shot of nos maybe 400?...idk tho......and too mjr46 i wasnt sure...didnt really think about that lol dumb question...so u think a 3800 stall should be fine?.
