Turn signals won't work
I was driving along tonight and realized that my turn signals don't work. I checked my 4 way flashers and they work so im thinking it's a fuse or something? When i push the turn signal lever nothing at all happens no flashing green arrow or anything but the green arrows work for the 4 ways any ideas? Also i installed a stereo with a sub not too long ago could this be affecting the turn signals?
RE: Turn signals won't work
pretty common. flashers run off of a different flasher box then the turn signals. sounds like u need to replace the flasher for the turn signals. u can find the flasher under your dash near the steering column. first make sure your connections on it are good and then try it. they sometimes losen up or get dirty and get a bad connection. if not the replcae it. alot of people will also tell you to play with your hazard button. just take it and flip it on and off repeatedly. i dont remember the reaosn behind it but i got mine to work after i played with everything so its worth a try
I can't find the flasher, where is it exactly and what does it look like? I pulled the one out from the back of the fuse panel but then the 4 ways didn't work so im assuming that's the other flasher?
KEM Motorworks
08-14-2015 10:13 PM
