87 gt not working
87 gt not working
i jus picked up a 87 mustang gt and it was running not so great .....hen i ingaged ther clutch it would not accerate and i had to rev the engine to accleratete....when i engaged the clutch normally it would do alot of jerking and/not respond...........when it idled iy wound jump around a liltlte then die but start right back up .......after about 10- 15 mmins of driving the engine died and now it will not start
i think it may bet athe injector o rings .....,fuel filter or pump if not the fuel regulator
87 mustang gt fuel injected 5 speed/manuel
anyone think they can help me out
thanx
thanx
RE: 87 gt not working
correct me if im wrong but from what i understang your saying when you release the clutch pedal the car is not moving? when you push the gas pedal its starts to move, sounds like the clutch is badly slipping, please take your time typing so we can clearly understand what your saying and help you out,
when i engage the clutch into gear it works fine but the engine dosn't respond when i hit the gas or it starts to jerk the whole time .....its when i engage the clutch that it dosn't do any thing unless i rev the engine and get the rpm up and then engage then i responds ands accelerates rpms
the clutch it pretty good it lost traction a few times and clutch dosnt seem to be slipping
ORIGINAL: 945LSTANG
try replacing the fuel filter and run fuel system cleaner in your next tank.
your ignition could probably also use a tune-up.
