car has bad lean on passenger side
The car has a nasty lean.The driver side is sittingmuch higher than the passenger side.The entire driver side is about 1.25 inches higher. This became very noticible after i got new spirngs, shocks, struts, uppper andlower control arms and tires. Its almostembarassingto drive it around. I have made sure the springs are lined up correct on both sides andalso put in new isolators for the rear springs. This helped out and leveled the car about 1/4 of an inch.
I still have 1.25 inches to go and have checked everything else. Ineed any helpor ideas you guys have soI can bring her back to level.
thanks
thanks
RE: car has bad lean on passenger side
Yep they all matched up corectly , what i might do is switch the to rear springs and see if i stil have the lean on the passenger side or if it changes whit the spring. That way I will know if its the spring or a bigger issue.
i'm having the same problem with the stock suspension on my stang.
I'm probably getting new shocks and springs all around to try and fix it.
Since your stuff is new, just try switchin the springs like you said, to see if things change. then you know your problem!!
I have that same problem with my 83 and its stock v6 suspension with a v8 motor. I have a bad strut though. I can wiggle mine around at the top of it and when I push down on it I can here it make a knock type sound. It didn't start the lean until I started driving it. Then I could sit on the front of the car and it would drop a little and then the passenger side would drop a little more. Sometimes the more I think about it I could (I do need to upgrade them too) need some springs.
ORIGINAL: Detroit_Muscle
thanks
thanks
Did you have this problem before you switched everything out?
Are your torq boxes in good repair?
i have the same problem with my 87 gt my driver side sits lower than my passenger side.....but i had a blown out rear shock on my driver side so maybe it wore down my spring
Yes the struts are adj. I have adjusted them with no luck. The torq boxs have been checked and are in good shape. The lean was there but you could bearly notice it. I figured changing everything with new parts would fix it, but just made it worse.
I had the same problem with my FRPP B-springs. First batch had a defective rear spring and made that corner about 1" higher than the other side. When summit sent the replacement set and I pulled that spring out it was obviously too tall.
I think your plan of changing sides with the spring sounds reasonable if you already checked them for height before installation. Could be that one is wrapped wrong or something.
inyadreems
08-21-2015 09:10 AM
Milan Dragway
08-12-2015 03:43 PM
