Fuel Filter?
Fuel Filter?
I just had a really dumb question, what would happen if you would to put a fuel filter on backward? Would it idle weired and not run right, or would it just idle and run fine?
I'm having idle problems, I have cleaned the IAC,TPS,MAF,Throttle body. I have checked the timing 3 or 4 times with a timing light, there are no vacuum leaks-checked the with a smoke machine, and it still wont idle right and seams that it is lacking some power. Ieven had to adjust the idle screwon the throttle body just so i could drive it, and it still wants to die some times when i come to a stop.
RE: Fuel Filter?
Maybe one of the sensors needs replacing...
http://www.ashentep.com/webpages/mus...mustang_gt.htm
Some good info
Some good info
RE: Fuel Filter?
I have already done all of that on the web page, but thanks tho, I just can figure it out so I just might take it a a guyI know that is a mechanic. He has done alot of work for me in the past, butI just wish that I could fix it soI don't have to Weight for him to do it.
Any other advice for me that could be the problem?
RE: Fuel Filter?
The only other problem I have ran into is the MAF not being plugged in all the way...It looked like it was but those things are dependent on voltage signals and can really mess things up. I guess just do a very good once over of all connectors and vacuum lines just to be sure. You don't want to be wasting that guys time either, so hopfully you'll find it if its easy....
RE: Fuel Filter?
So if a fuel filter is on back wards will it cause a car to not idle right , and make it seem that it has no power? The car starts fine and I can drive it but it wants to die when I stop and don't want to idle right
