replace Stock Cam for MPG
Old 05-13-2008, 04:21 PM
Hamutoff
Hamutoff's Avatar
Default replace Stock Cam for MPG
Does anybody know if there are ots cams for 87-93 5.0 mustangs that will net better MPG all else being equal?
I hear that while the stock cam is good, the factory did not grind them to the exact tolerances that aftermarket manu. use.
Anyway somebody threw out my stock 1989 5.0 H.O. cam so I need to buy SOMETHING... and this car is just DD for my gal and I... 90% highway miles I expect
THANKS [sm=bangbang.gif]
Hamutoff is offline
Old 05-15-2008, 12:15 AM
Hamutoff
Hamutoff's Avatar
Default RE: replace Stock Cam for MPG
any suggestions or comments? how about these two from ISKY?:
PART NUMBER: 371257/265
GRIND NUMBER: RR-257/265 HYD
RPM RANGE: 1400-5600
INTAKE TIMING
DURATION: 257 deg.
OPEN: 16.5 BEFORE TDC
CLOSE: 60.5 AFTER BDC
CAM LIFT: .30"
VALVE LIFT: .480"
EXHAUST TIMING
DURATION: 265 deg.
OPEN: 64.5 BEFORE BDC
CLOSE: 20.5 AFTER TDC
CAM LIFT: .313"
VALVE LIFT: .50"
LOBE CENTER: 112 deg.
OVERLAP: 37 deg.
PART NUMBER: 371252/257
GRIND NUMBER: RR-252/257 HYD
RPM RANGE: 1200-5000
INTAKE TIMING
DURATION: 252 deg.
OPEN: 14 BEFORE TDC
CLOSE: 58 AFTER BDC
CAM LIFT: .291"
VALVE LIFT: .465"
EXHAUST TIMING
DURATION: 257 deg.
OPEN: 60.5 BEFORE BDC
CLOSE: 16.5 AFTER TDC
CAM LIFT: .30"
VALVE LIFT: .480"
OVERLAP: 30.5 deg.
Hamutoff is offline
mirandaandjimmy
11-16-2015 08:51 AM
5.0pntydrpr
08-27-2015 10:26 PM
Tyoung68
08-25-2015 04:31 AM
ding56
08-14-2015 02:40 AM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: replace Stock Cam for MPG
