back firing through carb
it's back firing through the carb would the carburetor make it does this, i know timing would but i've moved it all over tryng to get it right and i change the distributor cap andchecked the plugs the car sounds fine at a idle, i rebuilt the carb myself first time that's why i was thinking carb. If not the carb what else should i check.
RE: back firing through carb
The carb could be causing problems but did you remove the distributor and put it back in. While carb is running check for leaks at idle but it really sounds like a timing problem.
thanks for the feed back i had the firing order mixed up, had 8 and 4 in wrong place that was easy after 2 days of scracting my head i just assumed i had it right because i went over it so many times before i fired it up go
YoungStangsMan
09-05-2015 07:01 PM
