rocker arm install question
i was just wondering if anyone knows of any good tech articles i could read about installing a set of 1.6 pedestal mount rockers on my 89gt....also any articles on adjusting valves also..
RE: rocker arm install question
roll each cylinder up on tdc and follow firing order accordingly and tighten rocker pedastal bolt down until slight drag is felt on push rod and from there in 3/4 to 1 full turn the bolt should reaach 22 to 25 ft lbs of tourque if not a shim must be added accordingly
Yes, very good idea. Don't for get, you may want to check for proper pushrod length and rocker geometry, check the link:
http://www.compcams.com/Technical/FA...inGeometry.asp
Kenta08
09-02-2015 10:33 AM
