Gap spark plugs to .050" or .054"?
Old 05-14-2008, 05:28 PM
xB1u3xF1v3xO
xB1u3xF1v3xO's Avatar
Default RE: Gap spark plugs to .050" or .054"?
ORIGINAL: camaroeater
I think I'll just flip a coin I guess....tails=.045" and heads=.054". I hate doing **** when I not 100% sure about something.
somewhere .054 or a little below...you'll be fine.
xB1u3xF1v3xO is offline
Old 05-14-2008, 05:30 PM
BlackMagik
BlackMagik's Avatar
ORIGINAL: xB1u3xF1v3xO
That sounds pretty good imo. I can still look it up tomorrow for you.
BlackMagik is offline
Old 05-14-2008, 06:55 PM
67mustang302
67mustang302's Avatar
If it's n/a then gap larger, say .054. The larger gap makes for a larger longer spark that's a bit hotter and more likely to ignite the local air/fuel mix and generate a strong flame kernel. The problem with larger gaps is that they can cause increased electrode wear, so when they get excessive the plugs wear out faster(for reference some newer cars are running stock gaps of .060 in order to generate a large enough spark to "catch" some fuel in the lean mileage mixtures) and in higher compression and boosted applications the problem can be the hotter spark keeps the plug tip too hot and can possibly cause pre-ignition or you can get spark blow-out, where the force of compression literally "blows out" the flame kernel as it's trying to ignite the fuel charge. That's why any engine with too much gap for the setup will get high rpm misfires. Not enough gap and you'll have poor performance, fuel consumption increases, power may be low and throttle response can suffer. The only thing is that in order to run larger gaps you need higher voltage ignition systems to generate enough voltage to jump the high resistance gap(bigger gap = more resistance = more voltage required), that's why older cars with poor ignition systems ran much smaller plug gaps, usually less than .035 whereas modern vehicles or older vehicles like my 67 with modern high energy ignitions run .050 or more.
67mustang302 is offline
Old 05-14-2008, 07:49 PM
ctgreddy
ctgreddy's Avatar
if i was you and weren't sure i'd gap them at .052, right in the middle. that way your only 2 thou out of spec for either one, and come on 2 thou is so small you wouldn't notice any difference.
ctgreddy is offline
Old 05-14-2008, 09:35 PM
stang8689
stang8689's Avatar
What if you have a MSD 6AL, dizzy and coil, what would you gap them at?
stang8689 is offline
Old 05-14-2008, 10:07 PM
highspeed
highspeed's Avatar
ORIGINAL: ctgreddy
+1...
I had extensive conversations with the local machine shop and to my dismay... they put down the NGK's and said go with Autolite AR series plugs. I have a '94 GT 5.0Lthat is Naturally aspirated and I asked for the plug application for my car. They told me AR13's were the way to go.
The AR series Autolites are constructed with a ground that only protrudes half way to the electrode to give a more open spark for better combustion. The machine shop told me hands down these performed better than the NGK's in every dyno runthey tested them in.
Oh... and they told me the gap ona Naturally aspirated 5.0L should be .052 for optimum performance.
They weren't kidding about those AR series plugs... My car ran betterwith the AR's thenit ever did on any of the other plugsI tried.
highspeed is offline
Old 05-14-2008, 10:10 PM
highspeed
highspeed's Avatar
ORIGINAL: stang8689
That only changes the number of distributed sparks per cycle... has no affect on what the gapping should be.
Now if you run NOS or have forced induction, that's different. That would call for an entirely different gap setting and heat rating.
Old 05-14-2008, 10:14 PM
highspeed
highspeed's Avatar
ORIGINAL: 67mustang302
Well stated 67mustang302
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
firehorse02
11-16-2015 11:28 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: Gap spark plugs to .050" or .054"?
