setting tps help
setting tps help
1990 mustang gt 5 speed. Im trying to set my cousins tps and while the car is at idle its at 2.0 volts.then with the key on the on position and the engine off its also at 2.0 volts... the car is driving fine and the idle is good...im wondering if those numbers are ok or If i have to keep trying to adjust it
RE: setting tps help
When I did mine, I have the car off.........ignition key on
Ground the negative wire to the black wire (not a grounding point in the car), and positive to the green wire....
Keep it under 1 volt...
.96 - .98 is ideal
.96 - .98 is ideal
