i have a ?
RE: i have a ?
ORIGINAL: eliptical_illusions
ok so if i were to get a flywheel what kind should i get...incase i didnt **** the block up
RE: i have a ?
did you build the motor or did a machine shop?
if you did, you really should have sent out the balancer rotating ***. and flywheel to be ballanced. if you didnt, well this could be a big issue
what stroker kit is it?
and 500hp?[&:]
and 500hp?[&:]
RE: i have a ?
you used a 50oz flywheel on a stroker??? like adder says they are 28 most of the time........you can get one with a 28 oz removable weight..mine is a fidanza on my 347...but if you ran it like that for any length you might of screwed the bearings up and with the parts you listed...your not at 500 hp
RE: i have a ?
well me and my buddy did the rebuild and like i said earlier its a 331 and i just put the flywheel that i took off of it when we pulled it apart back on it...i assume it is the stock flywheel...and the crank was balanced when i got it
RE: i have a ?
dont EVER slap a rotating assembly into a block without having it balanced with your balancer and flywheel
EVER!
RE: i have a ?
dude, answer my questions...
what kind of stroker kit?
what balancer
who balanced it? the factory? yea get it balanced
honestly, w. the little info your giving us, i think your pulling your motor out in the next few days and redoing somethings
what balancer
RE: i have a ?
