Bracket for Dial Indicator
Old 05-15-2008, 09:08 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default Bracket for Dial Indicator
Has anyone taken the time to make their own bracket for a dial indicator to measure the lift of your cam?
I don't know the lift of my cam and I finally got ahold of a dial and now I need a bracket and I don't want to buy one. Anyone have any ideas??
projectresto83 is offline
Old 05-15-2008, 09:14 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Bracket for Dial Indicator
you can buy a magetic base for it.
Hell, i bought a dial indicator WITH a magnetic base, for $30
AdderMk2 is offline
Old 05-15-2008, 09:25 PM
projectresto83
M.A.D. Motorsports
Yea I know, but I was thinking of some bolts and little stuff for under $5.
Old 05-15-2008, 09:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'd need to put a solid lifter in place if taking a reading off the rocker or attach something to the push rod to take the reading without rocker in place but even then so it may not be terribly accurate
mjr46 is offline
Old 05-15-2008, 09:42 PM
projectresto83
M.A.D. Motorsports
I am not worried about being completly accurate with what I find. Just an idea. I am gonna change out the cam anyway when I put my GT 40's on. I can attatch a piece of metal coat hanger that is straight to put down on the cam.
I am gonna get some threaded rod to put into a valve cover bolt hole as the base. I just havn't thought to much on the upper have that cam be adjustable up and down to make sure I get the dial zeroed before I measure the lift.
But here is what I might do. Get a nut for that threaded rod and weld on a length of rod to the side of that nut at a 90 deg angle and the just have 2 nuts to lock the dial where I need it on the horizontal rod. that way it is adjustable up and down and left to right. Maybe cost me $5 in rod and nuts.
Old 05-15-2008, 09:46 PM
mjr46
mjr46's Avatar
^it's worth a try
mjr46 is offline
Old 05-15-2008, 09:48 PM
projectresto83
M.A.D. Motorsports
Yea, I am a cheap a$$ I know. Like I said before I am young with a wife, kid, one on the way and I just bought a house so every dime has to count when it comes to my baby in the garage.
cr620
10-03-2022 10:18 PM
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Bracket for Dial Indicator
