Just installed Headers and O/R H pipe...quick ?
Atstart up it idles at 750 rpms. Seems that after driving for 5 minutes, when I come to a stop it still idlesgoodat 750, butif I come to a stop for over1-2 minutes the rpms go from 750 to 550 for 1 sec. and then back to 750. If I just sit and idle, it willdo this every 2-3 minutes. Anyone have and idea what could cause this?
RE: Just installed Headers and O/R H pipe...quick ?
idle air control....
What about when you get on it--- let off at a high rpm 5-6k, and push in the clutch right away... what do the rpms go to??- really low, does it sink back down gradually, or just drop back to idle within an instant and almost stall?.
ORIGINAL: 1990NOS!
well my car has a cam so it lobes from rpm to rpm--- (700-550) when cold, then when i get to a light it takes a second to drop back down to idle. .. it'll sit at 800-1k for about 10-15secs then just start lobing at about 600pms when at idle temp....
You may just be concerned about nothing... if it's not popping on rev up, any hestitation, or stalling... i wouldn't be worried.
I got some hesitation on the way back from lunch. When I turned a corner in 1st, a little after I shifted into 2ndI was on the gas and it hesitated for a couple of seconds. Does anyone know what this could be?
ORIGINAL: Jon82387
You got your 02 sensors back in correctly right?
ihave the same problem so im curious to find out myself. does your volt gauge jump around too when idle drops down to 550?? mine is out of control when im at a stop light for more than 30 seconds and it goes from 750 to 550 also at start up i have to constantly save it until it reaches a temp 100* or greater.
and 1990NOS!:
i have popping and hesitation until i reach full operating and then nothing. i also experimented on my own with the "bring up to a high rpm and push the clutch in" mine just instantly drops to 750 idle and just maintains unless it idles for a little while until 30seconds ish and it drops to 550 and struggles.
and 1990NOS!:
ORIGINAL: FivePointOhh
and 1990NOS!:
and 1990NOS!:
Mine idles at 750-800rpms, but like you said, after about a minute it goes from 750 down to 600 and back to 750. Sometimes it will fluctuate at little back and forth from 750 down to 600 a couple times. My Idle has ALWAYS been at 750. Other than the RPM thing, I have no problems performance wise, I noticed the torque being hurt going O/R, but I notice more power in the high rpm range.
Hey Fivepointohh, my voltage gage drops when the rpms drop.
