putting oil pan gasket on with engine in
Old 05-18-2008, 07:44 PM
89stanger1989
89stanger1989's Avatar
Default putting oil pan gasket on with engine in
i got the engine in and i'm trying to put the gasket on with the two metal pieces but its very hard with the engine still in . motor mounts tranny is out. any tricks?
89stanger1989 is offline
Old 05-18-2008, 08:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: putting oil pan gasket on with engine in
undo motor mounts and jack the motor up
mjr46 is offline
Old 05-18-2008, 08:32 PM
89stanger1989
the motor mounts are out and the engine is jacked up.
Old 05-18-2008, 08:45 PM
mjr46
mjr46's Avatar
ORIGINAL: 89stanger1989
so what metal pieces are hard to get out.....your not talking about the strips that go under the bolts that run the length of the pan??? if so just undo all bolts and pop off with a screwdriver and pop pan down and lay rags in it so when cleaning gasket surface crap won't fall in pan and I BELIEVE YOU MAY NOT BE ABLE TO PULL PAN OUT ALL THE WAY DUE TO CLEARANCE ISSUES BUT if just replacing the gasket that's all you'll need to do
mjr46 is offline
Old 05-18-2008, 08:54 PM
stang8689
stang8689's Avatar
I just did mine a month ago and had no probs
stang8689 is offline
Old 05-18-2008, 09:18 PM
89stanger1989
i'm talking about putting them back on....they dont stay in place and fall in the pan or out the car. should i screw 1 side in at a time.. i never thought this would give me a problem but it is lol
Old 05-18-2008, 10:23 PM
Jon82387
Jon82387's Avatar
when i did mine i just did each side 1 at a time, id get just 1 bolt started and let it hang down then get another bolt started on the opposite side of the bracket
Jon82387 is offline
soulcaliber39
12-28-2016 04:57 AM
mirandaandjimmy
11-16-2015 08:51 AM
KEM Motorworks
08-14-2015 10:13 PM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: putting oil pan gasket on with engine in
