Cobra Brakes?
Old 05-21-2008, 10:57 AM
SPE926
SPE926's Avatar
Default RE: Cobra Brakes?
www.sn95brakes.com This site will tell you everything you need to know about the brakes
SPE926 is offline
Old 05-21-2008, 11:02 AM
SPE926
SPE926's Avatar
ORIGINAL: primetime5.0
94-95 spindles need to be grinded down just a little to clear cobra brakes, what kinda wheels are you going to run to clear the brakes?
Sorry that is incorrect. It is the later model pbr calipers on the gt's that require the grinding. the cobras have had essentially the same brakes from the 93 cobra r to the 04 cobra (excluding 00R) with the only change being rotor types/thickness (all were 13 inch, 98 had rotors that were side specific) and piston size in the calipers.
The difference between the spindles is that the 96-04 spindles are set up for a didderent front end geometery that widens the fox front wheel base. The 94-95 spindles are used mainly because of the fact that they keep the stock fox front suspension.
SPE926 is offline
88 orangepeel notch
10-05-2015 09:03 AM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Cobra Brakes?
